I am a beginner in Nautical cartography and I would like a link for a tutorial or a document that can help me create nauticaL charts and features using ArcMap
Hello @gha_bby ,
Online tutorials are not available at this time. If you simply want to visualize the ENC data as a paper chart, then I recommend you:
If you are looking for paper chart production documentation, then we have several guidebooks. They are located at: https://desktop.arcgis.com/en/arcmap/latest/extensions/maritime-charting/what-is-the-arcgis-for-maritime-charting-.htm
Could you please help me set up my product library to start paper chart production. I get this when seating up the library in a file geodatabae I created
Are you able to use ArcGIS Pro? ArcGIS Pro does not require a Product Library so the setup is simplified. If you have ArcMap, you should also have access to ArcGIS Pro.
My license doesn’t support ArcPro so I’m currently working with Arcmap.
Hello @GabrielAweya , looks like you are not using the right workspace XML. I posted the configuration steps for you in this topic: https://community.esri.com/t5/arcgis-mapping-and-charting-questions/set-up-arcmap-for-nautical-paper-charting/m-p/1290997#M2789
Hope it helps.
