I propose a functionality in the New Map Viewer -> Map Tools -> Location so the user is able to change the expected UTM zone for a map extent to a neighboring zone.
Example: Denmark is located across UTM zones 32N and 33N, but as approx. 80% of the country is located in zone 32N, we use that zone to reference all spatial data.
Meanwhile, when you want to specify a bounding box for a WFS connection by looking up the extent's coordinates using Map Tools -> Location, the tool displays zone 33N coordinates correctly for an extent. which is correct from a geodetic point of view. However, I need to read out coordinates referencing zone 32N coordinates. So, having the possibility of customizing the UTM zone to display coordinates for a neighboring zone instead, is highly requested.
Kind regards, Thomas Balstroem, Univ. of Copenhagen, Denmark
