I'm using ArcGIS Pro 3.0.3.
I'm doing some raster processing where I need functionality that the Arcgis tools don't provide. The data is a multidimensional raster. I thought XArray would be a good way to handle this. The conversion from raster to xarray worked fine. The xarray processing produced the desired results. The conversion back to raster is failing with a message about projection. To test things out I tried a simple in and out on the same data which failed.
import arcpy
temp_max_file = r"D:\r3_analyst_work\Climate_Change_Modeling\climate_envelope\GridMetData_2020\tmmx_2020.nc"
test_rast = arcpy.Raster(temp_max_file,True)
test_rast_xr = arcpy.ia.RasterToXarray(test_rast)
out_rast = arcpy.ia.XarrayToRaster(test_rast_xr)
This produces the following message:
RuntimeError Traceback (most recent call last)
In [144]:
Line 1: out_rast = arcpy.ia.XarrayToRaster(test_rast_xr)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\RasterToXarray.py, in XarrayToRaster:
Line 377: arcpy.DefineProjection_management(myraster, srs_stand)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py, in DefineProjection:
Line 13701: raise e
Line 13698: retval = convertArcObjectToPythonObject(gp.DefineProjection_management(*gp_fixargs((in_dataset, coor_system), True)))
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py, in <lambda>:
Line 512: return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Unspecified error
