I need some help on a script that i am putting together.Script is as follows.1. Select feature2. Export the selected feature3. Load the export feature4. Label the featureI have a shapefile with a joined table in Arcmap. The script runs fine until it gets to the labeling part. I get back Acres filed does not exist to lable. I check the "NewFeatures" layer and i noticed that the attributes fields names were named after the feature class name like vector_D_3, Vector_D4, etc.. and not the actual tables names.I have attached a picture of what the tables looks after the copyfeatures_management.Here is my code.import arcpy,os, sys import arcpy.mapping # Set workspace arcpy.env.workspace = "C:/Temp" arcpy.env.overwriteOutput = 'True' directory="C:/Temp/Split.pdf" if os.path.exists(directory): try: os.remove(directory) except: print "Exception: ",str(sys.exc_info()) else: print 'File not found at ',directory #arcpy.RefreshActiveView() mxd = arcpy.mapping.MapDocument("current") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "TaxParcels")[0] df.extent = lyr.getSelectedExtent() df.scale = 5000 if int(arcpy.GetCount_management("TaxParcels").getOutput(0)) > 0: #arcpy.CopyFeatures_management("TaxParcels", "C:/temp/NewFeatures.shp") arcpy.Select_analysis("TaxParcels", "C:/temp/NewFeatures.shp") #Adding Labels layer = arcpy.mapping.ListLayers(mxd, "NewFeatures")[0] if layer.supports("LABELCLASSES"): for lblclass in layer.labelClasses: lblclass.className = "vector_D_1" #This should be Account lblclass.expression = "[vector_D_1] & VBNewLine & Round([vector_D_5],2)" #these should be "ACCOUNT" & "ACRES" lblclass.showClassLabels = True layer.showLabels = True arcpy.RefreshActiveView() arcpy.mapping.ExportToPDF(mxd,"C:/Temp/Split.pdf", "")
