You can use an ElementLayer to display images or videos.There is a sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MediaLayerNote that Silverlight doesn't support tiff format though.So you will need either a 3rd party component or a conversion to a supported format (jpeg, png (no gif nor tiff)).
As far as I understand from the sample I will replace the Source="http://serverapps.esri.com/media/scec-shakeout-simulation-rt.wmv"line with the url of the imagery and I will be done , correct?
If I change the projection of the map, will this imagery also change projection?
Almost! You have also to set the esri:ElementLayer.Envelope to the correct map coordinates for your image.Nothing automatic. You have to adapt the envelope of your element to the map coordinates.
Doing this adaptation, are there any libraries I can make use of during calculation of this transformation between projections? Or am I on my own?
