''' --------------------------------------------------------------------------- --------------------------------------------------------------------------- program: TOA to NDVI.py Chris Bater GIS and Remote Sensing Technologist Wildfire Resource Information Unit Wildfire Management Branch Forestry Division Alberta Sustainable Resource Development 9th floor Great West Life Building 9920 - 108 Street Edmonton, AB T5K 2M4 Ph: 780-422-0669 Cell: 780-446-1899 Email: chris.bater@gov.ab.ca Date: September 2011 Purpose: Converts Landsat-5 TOA reflectance data to NDVI --------------------------------------------------------------------------- ---------------------------------------------------------------------------- ''' #---------------------------------------------------------------------- #Identify the directory containing the landsat data workspace = r"C:\_LOCALdata\temp" #---------------------------------------------------------------------- #---------------------------------------------------------------------- #Import and load modules #---------------------------------------------------------------------- # Import system modules import os, sys from osgeo import gdal import numpy as np import numpy.ma as ma #register the GDAL drivers gdal.AllRegister() driver = gdal.GetDriverByName('GTiff') #not sure if this is necessary driver.Register()#not sure if this is necessary print "" print "All systems go" print "Hit CTRL + c at any time to stop processing" print "" #---------------------------------------------------------------------- #Iterate through the landsat scenes and convert to TOA #---------------------------------------------------------------------- try: files = os.listdir(workspace) for f in files: if not f.endswith('tif'): continue name = f[:-4] #open the landsat TOA file TOA = gdal.Open(workspace + "/" + f) #get the image size rows = TOA.RasterYSize cols = TOA.RasterXSize bands = TOA.RasterCount if bands != 6: continue print "processing " + f #create an empty tif file outData = driver.Create(os.path.join(workspace, name + "_NDVI.tif"), cols, rows, 1, gdal.GDT_Float32) outBand = outData.GetRasterBand(1) #assign the bands to variables b3 = TOA.GetRasterBand(3) b4 = TOA.GetRasterBand(4) #set the initial blocksize for analysis xBlockSize = 5000 yBlockSize = 5000 for i in range(0, rows, yBlockSize): if i + yBlockSize < rows: numRows = yBlockSize else: numRows = rows - i for j in range(0, cols, xBlockSize): if j + xBlockSize < cols: numCols = xBlockSize else: numCols = cols - j #read bands into arrays d3 = b3.ReadAsArray(j, i, numCols, numRows).astype(np.float32) d4 = b4.ReadAsArray(j, i, numCols, numRows).astype(np.float32) #mask no data values (no data = 0) m3 = ma.masked_equal(d3, 0) m4 = ma.masked_equal(d4, 0) del d3, d4 ndvi = (m4 - m3) /(m4 + m3) del m3, m4 outBand.WriteArray(ndvi, j, i) # flush data to disk, set the NoData value and calculate stats outBand.FlushCache() outBand.SetNoDataValue(0) stats = outBand.GetStatistics(0, 1) # georeference the image and set the projection outData.SetGeoTransform(TOA.GetGeoTransform()) outData.SetProjection(TOA.GetProjection()) #memory management del TOA, outData, outBand print 'script complete' except Exception, e: # If an error occurred, print line number and error message tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
however the documentation says that you can use a raster for the cell size. Not sure where I am going wrong here.
