Hey there,
I'm at a loss for why I cannot edit the location of a feature accessed via a geopoint question.
I have existing survey data that I import from the INBOX. I then use the geopoint question referencing the layer containing the point I wish to move.
I am able to accept the new location in the Geopoint question, and then it seemingly successfully submits the survey record with the new location.
When I re-load the survey via refreshed INBOX, the point is in the same location pre-edit. Or, perhaps I should say, the symbol for the point feature is in the same location pre-edit. The map cursor is in the correct target location to where I had moved the point.
I've tried opening the map after the submit to see if it was just not showing the target location updated in S123, but the edit does not appear to make it to the hosted layer.
Is there a setting that I'm missing?
I have one geopoint for the parent layer and I have one geopoint question for a repeat layer.
Thanks for any ideas.
BKS
- S123 Connect 3.15.170
- S123 field app 3.15.151
- Windows 10
PS - behaves same on Android and iOS field app
