Situation : you have a layer in TOC, then right click and properties display, then go to Definition Query then Query Builder.
I been trying to mimic this procedure using Arc objects with C#,
as an example :
IQueryFilter pQueryfilter = new QueryFilterClass();
pQueryfilter.WhereClause = "Num ='" + comboBox2.Text + "'";
IFeatureSelection pfeatureselection = pFeatureLayer as IFeatureSelection;
pfeatureselection.SelectFeatures (pQueryfilter, esriSelectionResultEnum.esriSelectionResultNew, false);
but the code above it doesn't do what I want : the code above select the features eventually will zoom into......, but still, if I go to my table I can see all the records and highlighter the selected ones, I just want to see in my table those ones selected as it is under Query Builder. It is possible to do it?.
I know that there is a way to create a new layer from the selected features and added to the project depending in the selection but this is not what I want either.
