I am periodically editing an existing survey, which is an open-end questionnaire. For example, I add new fields, delete existing fields, add new logic, etc.
Recently, while making a modification to the survey, I encountered a schema compatibility issue. I had made a copy of the survey to try the changes, then I copied them into the original excel. However, I didn't save a copy of the original excel before trying to publish the new version. Since I did it on multiple sessions, I lost the "undos" - fortunately I was able to manually revert back to a version that did not have compatibility issues.
Can someone please recommend a reliable workflow - step by step - for working on tests and modifications, and then safely publish modified surveys?
Diego
I use Survey123 - Version 3.15.175
