I have migrated an toolbar initially developped for ArcGis 9,3. This tool is used by non-programmer or cartographers.
One procedure is called to generate centroids of attributes table and after to launch an calculation.
Anyway,
The source code used in 9,3 was :
(A)
'instantiating new calculator and cursor
pCalculator = New Calculator
pCursor = CType(pFeatureClass.Update(Nothing, True), ICursor)
'Centroid Y
With pCalculator
.Cursor = pCursor
.PreExpression = "Dim pGeomShp as IGeometry" & vbNewLine & "Set pGeomShp = [shape]" & vbNewLine & "Dim pArea as IArea" & vbNewLine & "Set pArea = pGeomShp" & vbNewLine
.Expression = "pArea.Centroid.Y"
.Field = "centroidY"
End With
'try & catch *************************************************
Try
pCalculator.Calculate()
Catch ex As System.Exception
MessageBox.Show("Error: " + ex.Message)
End Try
This was working until moving to ArcGis 10 (an upper). A crash was observed while launching pCalculator.Calculate().
I’ve migrated this code that way (like proposed here http://gis.stackexchange.com/questions/52983/syntax-for-arcgis-icalculator-object/198681#198681 ) :
(B)
Dim nCentroidXFieldIndex As Integer = pFeatureClass.FindField("centroidX")
Dim nCentroidYFieldIndex As Integer = pFeatureClass.FindField("centroidY")
Dim nBldg_sizeFieldIndex As Integer = pFeatureClass.FindField("Bldg_size")
If TypeOf pFeatureClass Is IFeatureClass Then
If TypeOf pFeatureCursor Is IFeatureCursor Then
Dim pArea As IArea
Dim pFeature As IFeature = pFeatureCursor.NextFeature()
Dim myProgressCalc As New FileProgressForm
myProgressCalc.set_maximum(iTotalRecords)
myProgressCalc.Show()
myProgressCalc.Text = "Veuillez patienter svp"
myProgressCalc.lblProgress.Text = "Calcul des données géographiques"
myProgressCalc.Update()
pArea = CType(pFeature.Shape, IArea)
While pFeature IsNot Nothing
pFeature.Value(nCentroidXFieldIndex) = pArea.Centroid.X
pFeature.Value(nCentroidYFieldIndex) = pArea.Centroid.Y
pFeature.Value(nBldg_sizeFieldIndex) = pArea.Area
pFeature.Store()
pFeature = pFeatureCursor.NextFeature
myProgressCalc.Go()
End While
myProgressCalc.Close()
End If
End If
It’s working but it’s working extremely slowly ! The first code (A) was executed in less than 3 minutes. The new one (B) in 25 minutes !
In fact, I just want to programmaticaly call a the new calculate geometry tool (when displaying attributes table - http://desktop.arcgis.com/fr/arcmap/10.3/manage-data/tables/calculating-area-length-and-other-geometric-properties.htm )
Screen capture 1
Too bad, can't upload PNG and JPEG files...
or Arc tool => Data Management Tools => Entities => Add geometric attributes (http://pro.arcgis.com/fr/pro-app/tool-reference/data-management/add-geometry-attributes.htm )
Screen capture 2
or any other methods !
Both tools are working great in ArcGis Desktop but I can’t find my way to make them work in VB.NET.
Please, any suggestions ? (It’s just driving me crazy).
Thanks by advance for your answer, and sorry for screen capture in french and for poor english speaking
Matthieu
