I want to create unique asset nr using Arcade expression to display the numbers and letters from domain field and a sequence number
for example
Road_type → CR
Location → 01
Sublocation → 22
CR0122-0001
CR0117-0002
CR0251-0003
Create a database sequence: Create Database Sequence (Data Management)—ArcGIS Pro | Documentation
Use this expression in the attribute rule:
// Calculation Attribute Rule for the ID field // triggers: Insert, Update // Exclude from application evaluation // If there is already a value in the ID field, return that if(!IsEmpty($feature.AssetNumber)) { return $feature.AssetNumber } // get all the parts for the unique id, format them correctly var parts = [ $feature.RoadType, Text($feature.Location, "00"), Text($feature.Sublocation, "00"), "-", Text(NextSequenceValue("NameOfTheSequence"), "0000") ] // concatenate and return return Concatenate(parts, "")
Thanks, Johanes
