Hi All.
What's the best workflow for classifying lidar point clouds? When I decompress to LAS and, in ArcPro 3, create an LASD then run statistics, I get Ground, unassigned and, maybe, towers or something else but not vegetation heights or buildings. Should I do building footprints first, then classify the rest by height? Is the Ground tool better than or different from how Ground is created when calculating statistics and should I just reclassify everything to unassigned and then just go one classification type tool at a time?
I'll eventually want to estimate density of veg for different height classes and export to a raster. How do I eliminate multiple sampling from adjoining flightlines? I know there's a tool for that and it requires tiling. Where would that fit into a workflow. So:
LASD ==> Eliminate overlapping flightlines/oversampling (??) ==> Classify Ground ==> Classify building footprints (??) ==> classify buildings (??) ==> classify by height for vegetation.
Or can footprints & buildings be done after veg.
I have successfully derived DEM, DSM, and nDSM. How would those best fit into the above for analysis and/or classification if at all.
Is LASTools better for this?
OK. Hope that makes some sense. I've looked for a beginner's workflow on the web but only finding bits and pieces and, of course, in such demos, everything always works -- which is usually not my experience without a lot of flailing. I appreciate any guidance folks can give me!
Thanks!
George
