I have created a View Layer from a Hosted Feature Layer which contains only the fields/filtered data I am interested in via the Visualizations tab. The data tab correctly shows the filtered subset of fields. I would then like to be able to export only those fields/rows in the View Layer as a csv. When I do an export on the View Layer, it exports the entire dataset from the Hosted Feature Layer. If I wanted that I would just export from the original. Am I missing something or is this a bug? (Create hosted feature layer views). Thx.
Hi Mary,
This behavior is planned to be changed in the upcoming release later this month. When an admin or owner exports, the view definition will be honored so the behavior will be the same whether you are owner / admin or not.
Chris
Well, I unfortunately found the answer. As an administrator of the data, I am unable to export a View Layer as designed. If the Owner or Administrator exports data from a View Layer, it downloads the entire original dataset. That makes exporting View Layers as administrators somewhat useless in my mind. You should at least have the option to export the whole dataset or only the View you want. Manage hosted feature layers—ArcGIS Online Help | ArcGIS
Even if you are an administrator, you should only be able to export the data that is available through the view. Verify that you used the set view definition option and not the filter. If everything looks correct, get in touch with tech support for further troubleshooting.
-Kelly
Unfortunately not true. "When users other than the owner or administrator export from a hosted feature layer view that has field or feature definitions applied, the exported file only contains those fields or features that the definition allows. When the owner or administrator exports, the definitions are not applied and the exported file contains all fields and features." I worked with an Esri rep on it, and it is not possible (at least last I checked).
