I found some basic intructions on how to install CityEngine silently, however I still need more info.
We want to be able to install CityEngine using an application called TEM (aka. BigFix). I have been able to do so with ArcGIS 10.3 so I assumed that the parameters would be the same.
Here is what I am doing for ArcGIS:
msiexec /i <setup location>\setup.msi ADDLOCAL=ArcMap,ArcCatalog,Python,GeoStatisticalAnalyst,SpatialAnalyst ESRI_LICENSE_HOST=SERVER_NAME SOFTWARE_CLASS=Viewer SEAT_PREFERENCE=Float INSTALLDIR1=C:\python DESKTOP_CONFIG=TRUE /qb
Following those same guidlines, here is what I have for CityEngine:
msiexec /i <setup location>\setup.msi ESRI_LICENSE_HOST=server_name SEAT_PREFERENCE=Float /qb
City engine does install when I pass this command line. However, upon launch I am given a message saying that I need to run the CityEngine administrator and set my license. I need to be able to pass these parameters so that I can push the install out to my labs and not need to have someone go and touch each machine.
