Using Connect, can the check mark symbol used for submitting be replaced to read as “Submit”?
Yes. You can use a "Note" field type with a specific question name to change elements of the UI, including the form title/description, submit button text, survey footer, and thank you screen. Here's the link to the article on exactly how to do it and a screenshot of the specific question names: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformnotes.htm#ESRI_SECTION1_31E80EF0A30346F2B083BA1524B378D9
EDIT: This only works for the Web App. It cannot be changed in the Field App (because it doesn't use text for the submit button).
Sign in to post, follow content, and more. New here? Register for free.
