<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.DrawEvent; import com.esri.ags.events.IdentifyEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import com.esri.ags.layers.GraphicsLayer; import com.esri.ags.layers.Layer; import com.esri.ags.tasks.IdentifyTask; import com.esri.ags.tasks.supportClasses.IdentifyParameters; import com.esri.ags.tasks.supportClasses.IdentifyResult; import mx.collections.ArrayCollection; import mx.controls.TextArea; import mx.rpc.events.FaultEvent; [Bindable] private var msgVisible:Boolean = false; [Bindable] private var identifyArrayCollection:ArrayCollection; private var identifyPoint:MapPoint; //DECLARE CONTENT VARIABLE [Bindable] private var content:String = ""; private function myClickHandler(event:MapMouseEvent):void { //CLEAR CONTENT VARIABLE this.content = ""; identifyPoint = event.mapPoint; var myGraphic:Graphic = new Graphic(null,null,null); var identifyParams : IdentifyParameters = new IdentifyParameters(); identifyParams.returnGeometry = false; identifyParams.tolerance = 5; identifyParams.geometry = identifyPoint; identifyParams.width = myMap.width; identifyParams.height = myMap.height; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.mapExtent = myMap.extent; for (var i:Number = myMap.layerIds.length -1; i >= 0; i--) { var layer:Layer = myMap.getLayer(myMap.layerIds); var url:String; if (layer.visible) { if (layer is ArcGISDynamicMapServiceLayer) { var dynamicLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer; url = dynamicLayer.url ; } if(url) { var identifyTask:IdentifyTask = new IdentifyTask(url); identifyTask.addEventListener(IdentifyEvent.EXECUTE_COMPLETE, onResult); identifyTask.addEventListener(FaultEvent.FAULT, onFault); identifyTask.execute(identifyParams); showMessage("", true); } } } myMap.infoWindow.show(event.mapPoint); } private function drawEndHandler(event:DrawEvent):void { myGraphicsLayer.add(event.graphic); identifyPoint = event.graphic.geometry as MapPoint; } private function identifyFeatures():void { } private function processIdentifyResults(identifyResults:Array):void { if(!identifyArrayCollection) identifyArrayCollection = new ArrayCollection(); for each (var identifyResult:IdentifyResult in identifyResults) { var title:String = identifyResult.layerName; var obj:Object = identifyResult.feature.attributes; var fld:String; var value:String; for (fld in obj) { value = obj[fld].toString(); //APPEND TO CONTENT VARIABLE content += fld + ": " + value + "\n"; } //ADD LINE TO SEPERATE content += "\n------------------------\n"; } //PROCESS INFO WINDOW var text:TextArea = new TextArea(); text.text = content ; text.width = 300; text.height = 300; myMap.infoWindow.label = "Results" myMap.infoWindow.content=text; clearMessage(); } private function clearMessage():void { msgVisible = false; } private function onResult(event:IdentifyEvent):void { try { processIdentifyResults(event.identifyResults); } catch (error:Error) { showMessage(error.message, false); } } private function showMessage(msg:String, swfVisible:Boolean):void { msgVisible = true; } private function onFault(event:FaultEvent):void { showMessage(event.fault.faultDetail, false); } ]]> </fx:Script> <fx:Declarations> <esri:DrawTool id="drawToolbar" map="{myMap}" graphicsLayer="{myGraphicsLayer}" drawEnd="drawEndHandler(event)"/> <!-- Symbol for Point --> <esri:SimpleMarkerSymbol style="x" color="0xFF0000" size="12" /> </fx:Declarations> <esri:Map id="myMap" mapClick="myClickHandler(event)"> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer" /> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" /> </esri:Map> </s:Application>
