How to trigger an event when that exclamation mark is added to the map ?
You can listen for the "edits" event directly on the source layer
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#event-edits
Unfortunately that does not work, any other idea ?
It appears that you are using the Editor widget, so I think what you want is to capture the "create" event of the underlying SketchViewModel instance. In that case, it would be something like:
editor.viewModel.sketchViewModel.on("create", function(evt) { if (evt.state == "complete") { //do something with evt.graphic here } });
