Hello!
I'm trying to use the analysis tool on point layers I created manually (from an external service), because I require getting heat maps.As I read the documentation on how the analysis works, it depends on the layer can be accessed from any arcgis server.In my case, this seems a bit difficult, because I do not know how I could upload a layer to ArcGIS Online before doing the analysis.
When I try to analyze these layers that exist only locally, I get these errors:
14:48:20.114 TypeError: g(...) is undefined Stack trace: https://js.arcgis.com/3.14/init.js:911:266 .cache["dojo/string"]/</k.substitute@https://js.arcgis.com/3.14/init.js:911:131 p<._updateAnalysisLayerUI@https://js.arcgis.com/3.14/esri/dijit/analysis/FindHotSpots.js:19:1 p<._buildUI@https://js.arcgis.com/3.14/esri/dijit/analysis/FindHotSpots.js:16:477 p<.postCreate@https://js.arcgis.com/3.14/esri/dijit/analysis/FindHotSpots.js:7:459 .cache["dijit/_WidgetBase"]/</f<.create@https://js.arcgis.com/3.14/init.js:1124:202 .cache["dijit/_WidgetBase"]/</f<.postscript@https://js.arcgis.com/3.14/init.js:1122:459 https://js.arcgis.com/3.14/init.js:98:190 https://localhost:9443/arcgisapp/widgets/Analysis/Widget.js:367:41 https://js.arcgis.com/3.14/init.js:167:294 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:189:431 .cache["dojo/Deferred"]/</f/b.then@https://js.arcgis.com/3.14/init.js:192:308 https://localhost:9443/arcgisapp/widgets/Analysis/Widget.js:347:1 https://js.arcgis.com/3.14/init.js:167:294 ha@https://js.arcgis.com/3.14/init.js:22:471 https://js.arcgis.com/3.14/init.js:23:202 ia@https://js.arcgis.com/3.14/init.js:23:89 fa@https://js.arcgis.com/3.14/init.js:23:144 pa/g@https://js.arcgis.com/3.14/init.js:25:380 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 EventListener.handleEvent*Ka@https://js.arcgis.com/3.14/init.js:29:91 r.injectUrl@https://js.arcgis.com/3.14/init.js:29:441 pa@https://js.arcgis.com/3.14/init.js:27:115 a@https://js.arcgis.com/3.14/init.js:5:295 https://js.arcgis.com/3.14/init.js:14:191 ia@https://js.arcgis.com/3.14/init.js:23:89 ma@https://js.arcgis.com/3.14/init.js:14:177 https://js.arcgis.com/3.14/init.js:28:171 a@https://js.arcgis.com/3.14/init.js:5:295 Xa@https://js.arcgis.com/3.14/init.js:28:155 pa/g@https://js.arcgis.com/3.14/init.js:25:218 https://js.arcgis.com/3.14/init.js:30:98 1 Widget.js:395:13 ._switchToAnalysisTool/</<() Widget.js:395 .cache["dojo/_base/lang"]/</g.hitch/<() init.js:167 .cache["dojo/Deferred"]/</k() init.js:189 .cache["dojo/Deferred"]/</f/b.then() init.js:192 ._switchToAnalysisTool/<() Widget.js:347 .cache["dojo/_base/lang"]/</g.hitch/<() init.js:167 ha() init.js:22 fa/<() init.js:23 ia() init.js:23 fa() init.js:23 pa/g() init.js:25 r.injectUrl/f<() init.js:30
And
14:48:21.422 NS_ERROR_MALFORMED_URI: Stack trace: k@https://js.arcgis.com/3.14/init.js:151:153 .cache["dojo/_base/xhr"]/</b.xhr@https://js.arcgis.com/3.14/init.js:185:209 .cache["dojo/_base/xhr"]/</b.xhrGet@https://js.arcgis.com/3.14/init.js:185:1 x@https://js.arcgis.com/3.14/init.js:901:503 d@https://js.arcgis.com/3.14/init.js:903:245 y@https://js.arcgis.com/3.14/init.js:909:274 e<.postCreate@https://js.arcgis.com/3.14/esri/dijit/analysis/HelpWindow.js:6:1 .cache["dijit/_WidgetBase"]/</f<.create@https://js.arcgis.com/3.14/init.js:1124:202 .cache["dijit/_WidgetBase"]/</f<.postscript@https://js.arcgis.com/3.14/init.js:1122:459 https://js.arcgis.com/3.14/init.js:98:190 .initHelpLinks@https://js.arcgis.com/3.14/esri/dijit/analysis/utils.js:5:188 https://js.arcgis.com/3.14/init.js:166:478 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:189:431 .cache["dojo/Deferred"]/</m@https://js.arcgis.com/3.14/init.js:189:357 .cache["dojo/Deferred"]/</f/this.resolve@https://js.arcgis.com/3.14/init.js:191:441 https://js.arcgis.com/3.14/esri/dijit/analysis/AnalysisBase.js:31:329 https://js.arcgis.com/3.14/init.js:167:294 c@https://js.arcgis.com/3.14/init.js:66:221 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 https://js.arcgis.com/3.14/init.js:904:16 c@https://js.arcgis.com/3.14/init.js:66:221 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:67:1 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:67:1 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 https://js.arcgis.com/3.14/init.js:185:298 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:189:431 .cache["dojo/Deferred"]/</m@https://js.arcgis.com/3.14/init.js:189:357 .cache["dojo/Deferred"]/</f/this.resolve@https://js.arcgis.com/3.14/init.js:191:441 .cache["dojo/Deferred"]/</a@https://js.arcgis.com/3.14/init.js:190:309 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:190:70 .cache["dojo/Deferred"]/</m@https://js.arcgis.com/3.14/init.js:189:357 .cache["dojo/Deferred"]/</f/this.resolve@https://js.arcgis.com/3.14/init.js:191:441 .cache["dojo/Deferred"]/</a@https://js.arcgis.com/3.14/init.js:190:309 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:190:103 .cache["dojo/Deferred"]/</m@https://js.arcgis.com/3.14/init.js:189:357 .cache["dojo/Deferred"]/</f/this.resolve@https://js.arcgis.com/3.14/init.js:191:441 .cache["dojo/Deferred"]/</a@https://js.arcgis.com/3.14/init.js:190:309 .cache["dojo/Deferred"]/</k@https://js.arcgis.com/3.14/init.js:190:70 .cache["dojo/Deferred"]/</m@https://js.arcgis.com/3.14/init.js:189:357 .cache["dojo/Deferred"]/</f/this.resolve@https://js.arcgis.com/3.14/init.js:191:441 q@https://js.arcgis.com/3.14/init.js:150:170 f@https://js.arcgis.com/3.14/init.js:154:199 EventListener.handleEvent*.cache["dojo/request/xhr"]/</d@https://js.arcgis.com/3.14/init.js:154:459 k@https://js.arcgis.com/3.14/init.js:151:105 .cache["dojo/_base/xhr"]/</b.xhr@https://js.arcgis.com/3.14/init.js:185:209 .cache["dojo/_base/xhr"]/</b.xhrGet@https://js.arcgis.com/3.14/init.js:185:1 x@https://js.arcgis.com/3.14/init.js:901:503 d@https://js.arcgis.com/3.14/init.js:903:245 y@https://js.arcgis.com/3.14/init.js:909:274 https://js.arcgis.com/3.14/init.js:905:250 c@https://js.arcgis.com/3.14/init.js:66:221 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 .cache["esri/IdentityManagerBase"]/</D<._doSignIn/d@https://js.arcgis.com/3.14/init.js:684:300 https://js.arcgis.com/3.14/init.js:690:1 c@https://js.arcgis.com/3.14/init.js:66:221 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:67:1 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 https://js.arcgis.com/3.14/init.js:904:16 c@https://js.arcgis.com/3.14/init.js:66:221 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:67:1 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:67:1 d@https://js.arcgis.com/3.14/init.js:66:10 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://js.arcgis.com/3.14/init.js:67:350 c@https://js.arcgis.com/3.14/init.js:66:401 d@https://js.arcgis.com/3.14/init.js:66:10 1 init.js:182:169 .cache["dojo/_base/xhr"]/</x() init.js:182 .cache["dojo/_base/xhr"]/</b._ioSetArgs/<() init.js:181 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.errback() init.js:68 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.errback() init.js:68 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.errback() init.js:68 .cache["dojo/_base/xhr"]/</b.xhr/<() init.js:185 .cache["dojo/Deferred"]/</k() init.js:189 .cache["dojo/Deferred"]/</f/b.then() init.js:192 .cache["dojo/promise/Promise"]/</<.otherwise() init.js:203 .cache["dojo/_base/xhr"]/</b.xhr() init.js:185 .cache["dojo/_base/xhr"]/</b.xhrGet() init.js:185 x() init.js:901 d() init.js:903 y() init.js:909 e<.postCreate() HelpWindow.js:6 .cache["dijit/_WidgetBase"]/</f<.create() init.js:1124 .cache["dijit/_WidgetBase"]/</f<.postscript() init.js:1122 d/<() init.js:98 .initHelpLinks() utils.js:5 .cache["dojo/_base/lang"]/</g._hitchArgs/<() init.js:166 .cache["dojo/Deferred"]/</k() init.js:189 .cache["dojo/Deferred"]/</m() init.js:189 .cache["dojo/Deferred"]/</f/this.resolve() init.js:191 n<._signIn/</</<() AnalysisBase.js:31 .cache["dojo/_base/lang"]/</g.hitch/<() init.js:167 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 d/<() init.js:904 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:67 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:67 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 c() init.js:66 d() init.js:66 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback() init.js:67 .cache["dojo/_base/xhr"]/</b.xhr/<() init.js:185 .cache["dojo/Deferred"]/</k() init.js:189 .cache["dojo/Deferred"]/</m() init.js:189 .cache["dojo/Deferred"]/</f/this.resolve() init.js:191 .cache["dojo/Deferred"]/</a() init.js:190 .cache["dojo/Deferred"]/</k() init.js:190 .cache["dojo/Deferred"]/</m() init.js:189 .cache["dojo/Deferred"]/</f/this.resolve() init.js:191 .cache["dojo/Deferred"]/</a() init.js:190 .cache["dojo/Deferred"]/</k() init.js:190 .cache["dojo/Deferred"]/</m() init.js:189 .cache["dojo/Deferred"]/</f/this.resolve() init.js:191 .cache["dojo/Deferred"]/</a() init.js:190 .cache["dojo/Deferred"]/</k() init.js:190 .cache["dojo/Deferred"]/</m() init.js:189 .cache["dojo/Deferred"]/</f/this.resolve() init.js:191 q() init.js:150 f() init.js:154
If someone can enlighten me or give me ideas how to get more information, I thank you.
