Hi. When I click on the Transform Tool I get this error message: "Error extracting link layer package.C:\Program Files\ArcGIS\Pro\Resources\LayerTemplates\Editing\en-US\Links2D.lpkx". The program cannot seem to find the shapefiles I am trying to edit. Any ideas as to what is going on?
Did you extract the package? or add the featureclasses prior to using Transform?
Package Layer (Data Management)—ArcGIS Pro | Documentation
@WadeG-FORstaff Does that path exist on your machine? C:\Program Files\ArcGIS\Pro\Resources\LayerTemplates\Editing\en-US\
Did you ever resolve this issue? I'm having the same problem.
@Shimona_Kealy Does that path exist on your machine? C:\ProgramFiles\ArcGIS\Pro\Resources\LayerTemplates\Editing\en-US\ ?
@Shimona_Kealy I had the same issue and just resolved with the help from ESRI Support.
It appears to be a system/software glitch, the “Links” won’t be able to extract from the layer package when activate the Transform tool. Below is the workaround:
Good Luck and hope this helps.
I also just had this issue after a recent update. This fixed it @EShek - thank you!
