When there are multiple actions added to one widget, it's hard to recognize which action does what. It would be very useful to have the ability to add names to Actions in the widget. Currently, all added Actions have the same label (Framework - please look at the attachment), so you have to check detail every of them to find a place where you need to make some changes. Renaming "Framework" would help to identify quickly what particular Action do.
I also agree this is needed.
I have set up a custom map app that has map, table, pie chart and bar chart all syncing with each other. Much time has been spent on configuration actions/trigger settings (and there is lots of them) but it's very easy to get muddled or miss one as all of them look the same - you have to click each one to find out what it refers to.
If we can name our configuration set up for expressions or label classes in map viewer - why can't we do that in Experience Builder for these actions/triggers?
The name can be optional - it can still display the default settings as now but then the "user defined name" below. You will then be able to quickly see what you have set up and order them accordingly e.g. Framework. Select data record. “Asset Points to Bar Chart”
I need this exactly.
Sign in to post, follow content, and more. New here? Register for free.
