Good day:
I am working on a project that requires me to take data from a file GDB table and update a non-gis table in an Oracle database. I have multiple Update Cursor scripts that I use to update GDB FC(s) and table(s) and have no problems with that. When I build the script to update the Oracle database table, I keep getting DBMS error [ORA-00923: FROM keyword not found where expected]
I cannot figure out what is going on and how to fix this. The fields, to and from and path(s) are 100% correct.
I've attached the update cursor python script. Is there something I am missing? I have 100% read/write permission on the Oracle database that is connected via an ODBC connection.
Is it possible that the ObjectID in the GDB table is causing a conflict since it doesnt exist in the Oracle table?
def AttributeUpdate(source_table, in_field, update_fields, join_table, join_key, join_values):
# Make sure there is matching number of join and update fields
update_dict = {}
if len(update_fields) == len(join_values):
for i in range(len(update_fields)):
update_dict[join_values[i]] = update_fields[i]
for k,v in update_dict.iteritems():
# Create Dictionary
path_dict = {}
srows = arcpy.SearchCursor(join_table)
for srow in srows:
keyrow = srow.getValue(join_key)
valrow = srow.getValue(k)
path_dict[keyrow] = valrow
del srow, srows
# Update Cursor
urows = arcpy.UpdateCursor(source_table)
for row in urows:
upkey = row.getValue(in_field)
if upkey in path_dict:
row.setValue(v, path_dict[upkey])
urows.updateRow(row)
else:
pass # skip nulls
del row, urows
print '\'%s\' field in "%s" updated successfully' %(v, p.basename(source_table))
else:
print 'ERROR: Number of update fields and value fields does not match'
if __name__ == '__main__':
DCSI = r'Database Connections\DCSI.sde\DCSI.MEWCO_TRANS_RATING'
GDB = r'C:\Users\cwafstet\Documents\GIS WORKING FILES LOCAL\ELECTRIC\MEWCo ELECTRIC SYSTEM.gdb\MEWCO_TRANS_RATING'
# Attribute Update
DCSI_fields = ['XFMR BANK RATING']
GDB_fields = ['XFMR_BANK_RATING']
AttributeUpdate(DCSI, 'XFMR BANK ID', DCSI_fields, GDB, 'XFMR_BANK_ID', GDB_fields)
