Hi there,
I would like to add a relationship class to one of my feature services.
There is already a GlobalID - ParentGLobalID relationship, and want to have second one based on a String (Name - ParentName).
I tried using ArcGIS Pro to achieve this, however,I'm getting this very useless error message here:https://pro.arcgis.com/en/pro-app/2.9/tool-reference/tool-errors-and-warnings/160001-170000/tool-errors-and-warnings-160251-160275-160270.htm
Is there a way to add this relationship via REST, or any other way?
Hi @MarcoPoetsch
This can be achieved using the ArcGIS Python API similar to below.
Process:
from arcgis import GIS ## connect to AGOL agol = GIS("home") ## get the feature service using the item id item = agol.content.get("FS_ITEM_ID") ## get the Feature Layer and its ID ## you might need to replace 0 with the proper layer index if more than one layer lyr = item .layers[0] lyr_id = lyr.properties.id ## get the Table and its ID ## you might need to replace 0 with the proper table index if more than one table tbl = item.tables[0] tbl_id = tbl.properties.id ## a dictionary containing the relationship properties for the Feature Layer ## REPLACE LAYER_FIELD with the name of your matching field in the layer lyr_rel_dict = { "name": "Layer_to_Table", "relatedTableId": int(tbl_id), "cardinality": "esriRelCardinalityOneToOne", "role": "esriRelRoleOrigin", "keyField": "LYR_FIELD", "composite": True } ## a dictionary containing the relationship properties for the Table ## REPLACE TABLE_FIELD with the name of you matching field in the table tbl_rel_dict = { "name": "Table_to_Layer", "relatedTableId": int(lyr_id), "cardinality": "esriRelCardinalityOneToOne", "role": "esriRelRoleDestination", "keyField": "TABLE_FIELD", "composite": True } ## update the relationship properties in the Feature Layer and Table lyr.manager.add_to_definition({"relationships" : [lyr_rel_dict]}) tbl.manager.add_to_definition({"relationships" : [tbl_rel_dict]})
Sweet. Thanks @Clubdebambos May I ask you how I would DELETE a relationship class? 🙂
I recommend asking this a separate question so it has its own answer and for others to find the answer to it the future.
here we go @Clubdebambos https://community.esri.com/t5/arcgis-online-questions/deleting-relationship-class-from-featue-service/m-p/1223738#M48430
