I've added a new terminal configuration in our UN, now I need to assign it to an asset. Using the Set Terminal Configuration tool errors out with this message:
ERROR 002571: Operation is not allowed once the topology has been enabled.
I'm confused by that because all the documentation I read says that this tool can definitely be run after the initial topology enable.
I'm connected as DB owner, portal owner, default version. topology is disabled.
