The idea is to allow the select_one question to take the value of a variable (or the answer given to a previous question). See the following example:
In the Survey sheet the proposed function capability is select_one ${variable_name}
In the choices sheet the value in the list_name table = stores. The selected value is stored in vendor name as defined in that table.
If the name value is valid one, then it can be used in the next question with the form select_one ${ } or select_multiple ${ }
