I am using ArcGIS Pro 2.9.1. I am using the Layer to KML tool, but when I export, the label that shows in ArcGIS Pro does not show when I open the KMZ file in Google Earth.
Did you ever figure out the problem?
We are having the same issue. We use the Layer to kml tool to save certain locations in a kmz file. We want the name of the location to show in Google Earth Pro first as like a header. Than you could click the location and get more info. But the problem is its displaying by the company name, instead of the location name so its difficult to look at the map if you know the names of the locations only.
We do make sure to set the field expression under Labeling correctly.
A co worker of mine does not have this issue and we are following seemingly identical workflows, Im just on 3.2 and they are on 3.1 both with Good Eath Pro 7.3.6.9796.
Any ideas?
