Hello everybody, I have been working and evolving this Hydrant flushing survey to include both clicking on the hydrant to flush then being able to generate a list of residual hydrants hopefully just using arcade expression / advanced S123 functionality. I took this recommendation to use dynamic choice lists from the S123 guru's themselves @BrettStokes and @IsmaelChivite at the ESRI USer Conference. Using the buffer option, it is able to pick up the other Hydrants and filter out non-operating hydrants.
However, I can only get the dynamic list to generate the list if I manually enter in the geopoint, it will not read my passover geopoint value that is generated by default opening the Survey. Can I alter the arcade expression to allow this functionality to work fully? I see that when I click on the point it maybe geocodes / generates some additional info that is used in the dynamic buffer that does not work with my popup pass?
I tried to use "calculate" to reference the geopoint field but that did not work. If I need to share more info /elaborate please respond and I will happily do so. I shared a skimmed down version of my survey123 form and took screenshot of expression but I can share anything else more you need! Desperate to have this work fully, so close.
UPDATE: Spreadsheet updated
Thanks!
