I am working on a project for school and I am trying to create new layers from an existing shp based on attributes. The problem I am having now is that the select by attributes is not actually selecting the appropriate items and exports a layer with the same amount of points as the first layer. I have double and triple checked I have the correct spelling of the data field and attributes. I have also used numerous other methods of creating the expression which return an invalid expression error.
The first screenshot is the error I get with an improper syntax for the SQL query. The second screenshot is the result of the code with a "working" syntax but it creates a new layer with a new name but is otherwise the exact same. Finally, the third screenshot is the csv used as the input.
