Hey there!
I'm running into a bit of an odd problem - when I use the 'select' tool under Maps, I can't get it to turn off! Has anyone have this happen before?
Oh goodness, the solution was simple. Click on the 'Explore' button to cancel it. 😖
Oh, it's not the selection on the map itself, it's the cursor! I can't get my cursor back to a normal one to do things like move the map because this stays toggled on:
I thought if I clicked it again that it would turn it off, but all is does is drop the menu down to pick a different kind of selection.
Open the attribute table of the layer from which you selected the values. There, you should see a "Clear" selection" button. Click it, and the selection should be gone.
Hi @AcdenHelios
Hope you are having a great morning! I am unsure of the issue you are experiencing, however, I would be happy to try and help if I can get a little more detail. Could you please share:
