The sliders to turn on and off header and footer in a survey are missing in the appearance tab...
Hello
I think that you are looking for the settings here -
It is in the Add + section on the right hand side right at the bottom of the page
Hi @JohnPlunkett this is a survey I have created with Survey123 Connect.. I do not have the Add + section....
Hi there
It looks like from your screen grab you have cropped part of the image - are you able to take a screengrab of the whole screen
The Add + button is the first one in that panel
Hi @JohnPlunkett , I hope the below is helpful. Thanks. Chiara
Hi @JohnPlunkett thanks for your response. Is there a way to remove the header bar? Title cell is empty in the setting worksheet but I can still see the bar - see the survey first page below (transparency levels cannot be changed)
@AssociazioneTerras Did you ever figure out how to hide the header/footer now that the options are gone for Forms created in Connect? I wonder if @JamesTedrick knows a way to do this other than appending "?hide=header,footer" to the survey URL? I use other parameters in my URL and they don't seem to play nicely with the ?hide=header,footer parameter.
Thanks for any additional info on this!
@BrantCarman @JohnPlunkett @AssociazioneTerras I'm having the same issue. Did anyone find a solution?
