I have been trying to create a script for dissolving several geodatabase feature classes on ArcGIS pro. However, the script does not seem to be working. Could someone tell me what the problem is. I have tried two versions (I am new to python and arcgis pro) :
arcpy.env.workspace = "D:\WB_Data\WB_gp.gdb"
fcList = arcpy.ListFeatureClasses()
output_name = "C:\\Users\\Bart Manders\\Documents\\ArcGIS\\Projects\\MyProject_Dissolve\\MyProject_Dissolve.gdb\\%s_Dissolve"
fields= ['gp']
for fc in fcList: arcpy.Dissolve_management(fc, output_name % fc, "gp FIRST", "MULTI_PART", "DISSOLVE_LINES", '')
I get an error 00622: Failed to execute (Dissolve). Parameters are not valid. **Error 000800
*The value is not a member of MULTI_PART| SINGLE_PART.
another version is:
fields= ["gp"]
for fc in fcList:
arcpy.management.Dissolve(fc, output_name + "\" + fc + "_Dissolve", "gp FIRST", "MULTI_PART", "DISSOLVE_LINES", "")
For this version I get the error
SyntaxError Traceback (most recent call last)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\ast.py, in parse:
Line 50: return compile(source, filename, mode, flags,
SyntaxError: invalid syntax (<string>, line 2)
