Arcade Form Calculation profile return types are: Date | Number | Text. It will be helpful to also return a Dictionary type. This could be used for ArcGIS Runtime apps, in case a few attributes can be calculate in the same expression.
I had this same thought about being able to return more complex objects (dict, feature, geometry, etc.), but it might be weird to have a dictionary return type without a matching dictionary field type. Arcade supports returning a JSONified string and then a way to read it in as a dict with the fromJSON() function. I use this approach a lot when fetching data from other layers as using featureSetByAnything can be very costly, so if I need multiple fields to fetch data from the same dataset or feature I just delegate the task to a single field that returns a jsonified string and use the result of that field as an in memory lookup resource.Building it looks like this...
//ASSIGNED TO // $feature["rsrc_service_info"] function getServiceInfo() { var serviceNumber = $feature["service_number"]; var serviceNumberDesc = DomainName($feature,"service_number"); // var serviceNumber = "'02081600.1658"; // TEST VALUE // var serviceNumberDesc = "'02081600.1658 (Placeholder)"; // TEST VALUE if (!IsEmpty(serviceNumber) && Find('Placeholder', serviceNumberDesc, 0) == -1) { serviceNumber = Replace(serviceNumber, "'", ""); var sql = "service_number LIKE '%" + serviceNumber + "'" var fields = ['service_number', 'service_status', 'task_id', 'keyword_id', 'permit_id']; var mapLayer = 'Service_Orders_Resource_Table' var fset = FeatureSetByName($map, mapLayer, fields, false); var ffset = Filter(fset, sql); for (var f in ffset) { break; } if (!IsEmpty(f)) { console('Building jsonText'); json = '{"service_number": "' + f.service_number + '", ' + '"service_status": ' + IIF(IsEmpty(f.service_status), 'null', '"' + f.service_status) + '", ' + '"task_id": ' + IIF(IsEmpty(f.task_id), 'null', f.task_id) + ', ' + '"keyword_id": ' + IIF(IsEmpty(f.keyword_id), 'null', f.keyword_id) + ', ' + '"permit_id": ' + IIF(IsEmpty(f.permit_id), 'null', f.permit_id) + '' + '}'; console('JSON Length: ' + Count(json)); console(json); }; } else { console(pad + 'Service Number is null or placeholder; return empty json'); }; return json; }; //START HERE var pad = '>>> '; var json = '{}'; return getServiceInfo()
And utilizing it looks like...
//ASSIGNED TO // $feature["service_keyword"] console('Set Service Keyword') var pad = '>>> ' var key = 'keyword_id' var value = Null; var json = $feature["rsrc_service_info"]; // var json = '{"service_number": "02081600.1658", "keyword_id": 83880}'; // TEST VALUE if (!IsEmpty(json) && json != '{}' && Find(key, json, 0) != -1) { var dict = fromJSON(json) value = dict.keyword_id }; console(pad + key + ': ' + value) return value;
Sign in to post, follow content, and more. New here? Register for free.
