<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> var map; require([ "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/parser", "dojo/ready", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!" ], function( Map, BasemapGallery, arcgisUtils, parser, ready ) { ready(function () { parser.parse(); arcgisUtils.createMap("ff0591055e3541ab951f3494c3553181", "map").then(function (response) { map = response.map; //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); }); }); }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;"> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Switch Basemap', closable:false, open:false"> <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;"> <div id="basemapGallery" ></div></div> </div> </div> </div> </div> </body> </html>
<script> var map; require([ "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!" ], function( Map, BasemapGallery, arcgisUtils, parser ) { parser.parse(); arcgisUtils.createMap("ff0591055e3541ab951f3494c3553181", "mapDiv").then(function (response) { map = response.map; //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); }); }); </script>
