I would like to see a setting or environment variable for Pro, like ARCTMPDIR in ArcMap, for specifying where temp files are stored.
Specifically I am running into issues running ArcGIS Pro in the AWS AppStream environment because User Profiles are exceeding the 1GB default limit enforced by AppStream. ArcGIS Pro is the culprit that is causing this problem, at it is creating temporary files within the User Profile when carrying out various geoprocessing tasks, which add up to more than 1GB, depending on the analysis.
So I am in need of a similar environment variable or in-application setting to tell ArcGIS Pro which directory to use for temp files, as was available in ArcMap.
Thanks.
