Hello,I work for a Motorway Maintenance Organisation.We use the Linear Referencing System as base of our location system.Our network is divided in many "Routes" (LRS Model).I want to implement a geoprocessing tool that allow the users to generate "Lines" features automatically, based on start and end points they define.Concept:The user enter a "start" and "end" point (Click on the Map)The geoprocessing tool locates these points (Locate feature along route) and then generate a new line feature (Make Route Event Layer).This is my problem:I don't know how it is possible to manage the "connexions" between the "Routes" with the Linear Referencing System.If the start and end points are on differents routes that are connected in the real world, how is it possible for the Linear Referencing System to detect this connection and for the "make route event layer" to "jump" from one Route to another ?Has someone have already work on that ?
Thank you very much.Yes I thought about this possibility. The Linear Referencing model we use is not suitable for Network Analyst (Route not connected) and it's managed externaly, we can't modify it. However I can create a network that interconnect my LRS model and define rules and direction of travel (for a motorway it shouldn't be to hard).Then I can create a geoprocessing tool that draws the "shortest route" based on the user defined "start" and "end" points and relocate the linear result on my LRS Route Model.It's sounds a bit like a makeshift job and I wanted to know if anyone knows another way of doing it.
