Is it possible with ArcGIS for SharePoint to connect an SP List with a hosted feature service in AGOL, so that when the list is updated the feature service is also updated?
Alternatively, is this a workflow that can be done using Power Automate?
Thanks Tim, I did indeed get this working using the ArcGIS connector.
My flow in Power Automate uses the Sharepoint [When an item is modified] trigger to pass the updated row to the hosted feature service using the ArcGIS [Update a record in a feature layer] action.
I found that I needed to be the owner all of the resources, including the SP List, hosted feature layer and flow to make it all work.
Hopefully you got this squared away. I was using survey123 trigger to create a new list, but just glancing and it looks like there are 3 feature layer triggers in power automate related to agol.
So looks like this will keep your list updated. Doesn't seem like a connection per se, but at least your 'copy' list will reflect the data in your agol layer.
-Tim
Can you share an example of your Power Automate workflow? Is there an intermediary step between the [When an item is modified] step and the [Update a record in a feature layer]? I want to JOIN the Sharepoint list and feature layer based on a certain field and update other fields in the feature layer with the changes from the Sharepoint list.
Yes, would be interesting to see the Power Automate workflow @ACrateau.
Yes, there is an intermediary step between knowing there is a change and updating the hosted layer. See attached.
1. When an item or a file is modified
2. Get changes for an item or a file
3 Update a record in a feature layer
That will do all changes. I'm only usually looking for certain changes, so after step 2, I put a condition in to check if the Status column has changed and then if the status column = a certain value. If those things are valid, I make changes to the layer. That may or may not be useful depending on what you are doing. In this case the flow fires a lot more (whenever there are list changes) than updates to hosted feature layer take place. Because if the status isn't what I want the flow just does nothing. So it can be confusing when reading the logs as it runs often.
