Hi all,
I'm relatively new to using the ArcGIS API for JS as well as web development and recently created a project that makes use of some maps and open data feature layers.
These work when I'm running the site locally but do not show up when on the deployed version. The site is deployed via Netlify and I've inputted the API key into the Netlify environment variables. I've attached some screenshots of what I'm seeing and the settings I have for the API key.
Any and all help would be super appreciated!
are you getting errors in the console? I'd imagine if it was the api key you would get a login prompt. What are you build tools? How are you referencing the API key env variables in your app? Maybe a repro project? Could be the browserlist? Could be something else, tough to tell.
There are some sample projects here you can look at too.
https://github.com/Esri/jsapi-resources/tree/master/esm-samples
I've seen this issue with default browserlist in some frameworks, check our note here with the react sample
https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-create-react-app#misc
Hi Rene,
Thanks so much for your response! To answer your questions:
It appears as if the login credentials are being accepted (like you mentioned, no login prompt) and I'm able to query the FeatureLayer for data but the maps themselves are just not being displayed.
Thanks again for any further potential insight,
Joshua
