I'm looking for some guidance -- or nudge in the right direction -- for how to rotate (and eventually move) in a scene which contains an ArcGIS Map. I have deployed an app to Oculus Quest 2 goggles, but I can only see the map data. When I rotate the goggles the view rotates with me (not expected... since I can't look around in my view). I'm trying to get expected rotation to work as a first step towards interaction/locomotion with an Esri map.
I've followed the Unity and Oculus doc + online examples, but I've been unable to set up an XR Rig in a way which is compatible with an ArcGIS Map and ArcGIS Camera. Per Esri "the Camera game object must have the ArcGIS Camera component and be a child of an ArcGIS Map game object" (link). At a high level it seems like the support the ArcGIS Camera and Location are adding to be able to display map data is _not_ compatible with recommended pattern for supporting camera rotation/position in VR goggles.
How then to set up an XR Rig and configure the arcgis camera to rotate/move the camera in VR goggles?
This seems like a common need for the Esri user community.
Beyond what I summarized above (XR Rig/Camera), I have also configured my scene's camera (including ArcGIS Camera) with a Tracked Pose Driver, but nothing is working. What I see is either of these two states:
A) "native" Unity objects + camera rotating as expected... but no map data visible
ArcGIS Map data visible... but with a) no support for camera rotation and b) no support for camera movement (not really expecting this yet given what I have tried and how the Esri camera-controller is written)
What is the recommended path forward from here? Is there a recommended set-up for an XR Rig which works with an ArcGIS Camera? Or, should I be starting the process of writing my own camera controller without any XR Rig (i.e. replacing this https://developers.arcgis.com/unity/maps/camera/#camera-controller)?
=Cory
