I have a .qpt template file which was exported from QGIS and I need to use the template in ArcGISPro. Is there anyway to import the file into ArcGISPro? Or does it have be converted into another file?
Thanks in Advance
Scott
A .QPT file is a QGIS Layout Template. It would not contain data, just the page elements and references to a Map.
Its Pro equivalent would be a .pagx layout file, and there is no converter.
QGIS I believe uses Shapefile which should be usable in ArcGIS pro
However, I believe to use the layout you will need to export it from QGIS as a kml and then import that
You may be much better off just creating the layout from scratch in Pro. Language barrier and all that
