Background
I want to control label classes down to the SQL filter level.
This is not the same as pausing all layers.
This helps with:
- Map Authoring
- Product QA
- Exporting/sharing scenarios to outputs quickly (PDF as an example)
- Consistency in ArcGIS Pro UX
Context
The functionality I would like to see falls in the SQL filter in the Label itself
Currently to see the label class without the filter I need to delete the query.
Idea
With both being logically similar, the Clear/Set Active filter functionality makes sense to be available in the Label SQL filter config also.
This would help with consistency in UX when coming across this SQL interface.
Reference
The Definition Query Documentation explains the idea of being able to Clear/Set Active filters using the tick icon in the green circle. See "Set the active definition query" section for the Definition Query Documentation, also screenshot below.
I'm more than happy to provide more information,
Regards
Melissa Brooks
Three Waters Planner
New Plymouth District Council
