I want to know how can I change the picture marker symbol after on click dynamically. When the user click on the symbol it will change to a dark red symbol.
You can replace the symbol with a new one, with a new url. graphic.symbol = newSymbol
This is my code. Can you please help me in adding the new symbol/image on click of a location pin. I am new to this Arcgis Api.
let centroidRenderer = {type: "simple",symbol: {type: "picture-marker",// url: "https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg",url: "images/Location-map.png",width: "26",height: "26"}};
let locationpin = new FeatureLayer({url:"https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Centroids/FeatureServer/0",renderer: centroidRenderer});
The story is a little different when using a FeatureLayer, changing the symbol on click requires you to edit the attributes in some way to distinguish it from other features on the map.
https://developers.arcgis.com/javascript/latest/visualization/data-driven-styles/unique-types/
You may not want that, since you can't or don't want to edit the data. Best option in that case is to create a new Graphic with the symbol you want, add it to a GraphicsLayer, and then use a filter via LayerView filter or Layer definitionExpression to hide the target feature.
https://developers.arcgis.com/javascript/latest/query-filter/#layer-and-layerview
Hi, I tried to use the click event for the images. That approach was also not working. I will share the code once that I tried to implement but it just highlights the symbol.It's not changing the image.
let locationpin = new FeatureLayer({url:"https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Centroids/FeatureServer/0",renderer: centroidRenderer});// var privateSchoolsPoly = new FeatureLayer({// url:// "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/PrivateSchoolEnrollmentNoRendering/FeatureServer/0",// outFields: ["*"],// opacity: 0.8,// renderer: renderer,// });
let symbol;
view.when(async () => {const layerView = await view.whenLayerView(locationpin);view.on('click', async (e) => {const {results} = await view.hitTest(e);try {const { graphic } = results.find(x => x.graphic.attributes.OBJECTID);if(symbol.url=="images/Location-map.png"){(symbol.url==" https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg")}else{symbol.url==" images/Location-map.png"}// fWidget.graphic = graphic;symbol = layerView.highlight(graphic);} catch(err) {}});});
view.when(function() {map.addMany([locationpin]);});
