Our group of inspectors is in the process of switching over from a Dell Rugged running Windows to Galaxy Tab S7s running Android and are trying to work out how to use a Handwriting to Text option in Survey123. The last I checked the Windows version of the field app allow the MS Handwriting keyboard to be used, but we are having trouble getting handwriting to text to function in Android.
I searched the community and only found a post from 2019(https://community.esri.com/t5/arcgis-survey123-questions/stylus-use-on-a-survey/m-p/828605 ) which seems like it should be a valid solution but isn't working any more.
In any other program (Gmail, SMS) the default handwriting keyboard (Samsung) shows up and works just fine. We installed GBoard and got it to function as intended in other apps as well. When we go into the Survery123 Field App, the handwriting keyboard for both the default Samsung Keyboard and the GBoard seems to be blocked by the Survey123 app and can't get the handwriting panel to appear.
We would like this feature to fill in the notes/comments fields in our Surveys. The image/sketch workaround will not work for our surveys.
Any thoughts, solutions, explanations?
