I want to use Survey123 to capture a search for real estates. Therefore I created an adress field, that uses the Esri World Geocoder, and a number field, where the user can enter the search radius in kilometer around the adress. With this input our real estate specialist can start looking for properties that lie within that circle.
Is there any possibility to display the adress and the search radius on a map below these field, so that the user is able to see the covered search area?
The even better solution would be to have the option to draw the search radius directly in the map, but I couldn't find any way to do that, so I changed the input to an adress field. Maybe someone has an idea how to do that?
Thanks a lot in advance!
Julia
