Please, why is this basic option not available? For example: representing quantitative values on the map only by size or color symbol is not appropriate.
Thank you in advance for your consideration.
Hi Martin,
Thanks for the idea. We will consider it.I'm not sure I understand your example perfectly. Apologies if I am misunderstanding.The verdict is still out on thematic map labels. In fact, a lot of cartographic research demonstrates the opposite of what I believe you're arguing here.
It is generally appropriate to represent quantitative values without data labels, as it reduces cognitive load during visual interpretation. For actual values, someone can look at a table or chart that is linked to the mapped value.
However, I understand sometimes you may want to add data labels to your map visualizations. Every design case is different, so it may be a good idea to add that option.
Thanks again for sharing the idea and participating in the community. We think about implementing this in a future release.
Most of all, thanks for using ArcGIS Insights!
Best,
Ian
Sign in to post, follow content, and more. New here? Register for free.
