Hi all,
I have learned that it is not a good idea to create a web map that will be shared with a group using any of the layers created in ArcGIS Online after publishing a survey from Survey123. My goal is to create a View Layer from the Hosted Feature Layer that is created after publishing the survey.
When I go to do this I get an error message that reads "This view layer could not be created. Try again."
I realize that I technically could just share the stakeholder layer with the group and make a web map with that layer, but as I have read, I do not think that is good practice.
Any thoughts as to why it will not allow me to create the view layer to use in my web map?
Thank you!
