Several times over the last 4 months, I have experienced an odd technical issue with ArcGIS Pro 2.9.2 that does not result in a crash but does cause Pro to be nearly unusable. I am just looking to see if anyone else has had similar issues or whether it is unique to me and my system.
I will be working in Pro performing edits, both spatial and attribute, after some action (which appears to be different each time, most recent was adding 4 points in quick succession) my left mouse button will cease to interact with any GUI element. If I click on the map within the current frame, Pro performs an identify and will display results. However, if I try to click on a different tool within the ribbon interface or switch to a different pane or attempt to turn on or off a layer, nothing accepts the click. Right-clicking still appears to function normally, both on the map frame and ribbon interface. Keyboard commands still work also.
My current workaround is to use keyboard commands to save edits, turn off the edit session, save the project, and close Pro. Once I open Pro back up, it will perform normally. This has occurred 2-4 times within the last 3-4 months. (EDIT: Use the Alt key to access the GUI followed by letters or numbers to access functions)
Has anyone else experienced odd left-click behavior similar to this recently? Since I cannot reproduce the issue and it appears to be random, I do not think a support ticket is warranted. Just trying to gauge whether this behavior is unique to my system or if any other Pro users have experienced something similar.
Thank you for reading this far and providing any comments.
