Hi all,
I am building an application in SWEET for ArcGIS and want to create a dynamic drop down list for a field. I want the options to show possible values based on a hosted lookup table; basically a dynamic domain. I can't actually use a domain so I need to figure out how to do this...
There is an example in SWEET for creating a static list of possible values, but I'm not sure how to do this by reading off a table. In python, I would read the table, and for each record in the field, I'd add the value to the list. Then I would return the list, and those would be the options.
I'm not really sure how to achieve this in Arcade, it seems like it uses "arrays" instead of "lists" for this functionality. How do I add values to an array in Arcade?
Here's how I wish the script would work...
var TestingPolicies = FeatureSetByName($map,"Testingpolicy")
var options = []//create empty list
for (var record in TestingPolicies){
var option = record.DCA_Type
options.append(option)//add each option to the list
return options
And here's the sample code for making a 'static' list using the SWEET configuration "Scripted Choice for [Field Name]":
return {
choices: [
value: "A",
label: "AAA"
value: "B",
label: "BBB"
value: "C",
label: "CCC"
static: true // If static, the script will only ever execute once. Use for lists that do not change
