I currently have a dashboard that has a Category Selector to filter the "RLType" in a dataset and a Serial Chart that uses a data expression that summarizes the RLType across multiple fields and returns a Sum. Without going in to detail of the actual data expression, is it possible to match the Actions in the Category Selector to filter the Serial Chart that is derived from a data expression? When I try to Filter the Chart, there is not a matching field that I can select, even though they are essentially using the same data (the selector and chart). Has anyone successfully done this before? Am I approaching this incorrectly? Thank-you.
The Image is from the Actions tab in the Category Selector where I would like to create the filter on the chart.
