Please can you include the ability to protect the configuration of an ArcGIS map project so that the project can be shared without needing to publish it as a web map.
So my requirement is to create a map and add layers from an enterprise geodatabase, set which layers are selectable and editable, use data design/fields to set visible and read only fields.
So far so good we can achieve everything up to this point.
Now the enhancement request part, once configured as per the above description I need to lock the configuration so that I can give the project to other users but not allow them to change anything in the configuration such as adjusting which fields are read only.
I know I can achieve this by publishing the project as a web map that a user can download into pro but this is at a performance cost our workflow would be more efficient with the users working directly from the database.
Think of it like setting up an excel spreadsheet clicking on protect sheet, set the desired user controls and setting a password.
