The Attribute Rules documentation says:
Attribute rules are complementary to existing rules used in the geodatabase, such as domains and subtypes. For example, domains can be assigned to an attribute field to aid in the data collection process by providing a list of valid values for editors. Additionally, an attribute rule can be used to restrict values for an attribute field that are not part of the domain when performing a field calculation. After rules are added to a dataset, they can be evaluated as edits take place or at a later time.
Question:
What is involved in setting up an attribute rule to enforce a coded value domain? I.e. prevent non-domain values from being entered, even when tools like the field calculator are used.
- Do we need to hardcode the domain values in an IF statement in Arcade?
- Or can we reference the domain list in Arcade and use it to dynamically restrict values in a field?
Thanks.
