TypeScript code:
const url = '<REDACTED>/server/services/CRSMS/results_views/MapServer/WFSServer';
wfsUtils.getCapabilities(url).then((capabilities: __esri.WFSCapabilities) => {
console.log(capabilities);
wfsUtils.getWFSLayerInfo(capabilities).then((layerInfo: __esri.WFSLayerInfo) => {
console.log(layerInfo);
}).catch(err => console.error(err));
Full error object:
"name": "wfs-layer:getWFSLayerTypeInfo-error",
"message": "An error occurred while getting info about the feature type 'CRSMS_Results:State_Segment_Results'",
"details": {
"error": {
"stack": "TypeError: e[0].toFixed is not a function\n at http://localhost:4200/default-src_app_countermeasure-selection_countermeasure-selection_module_ts.js:1220:24\n at Generator.next (<anonymous>)\n at asyncGeneratorStep (http://localhost:4200/vendor.js:488874:24)\n at _next (http://localhost:4200/vendor.js:488896:9)\n at ZoneDelegate.invoke (http://localhost:4200/polyfills.js:10741:26)\n at Object.onInvoke (http://localhost:4200/vendor.js:150275:33)\n at ZoneDelegate.invoke (http://localhost:4200/polyfills.js:10740:52)\n at Zone.run (http://localhost:4200/polyfills.js:10503:43)\n at http://localhost:4200/polyfills.js:11645:36\n at ZoneDelegate.invokeTask (http://localhost:4200/polyfills.js:10775:31)",
"message": "e[0].toFixed is not a function"
I tracked down the line in wfsUtils.js that attempts to call e[0].toFixed, and the error seems to stem from trying to run toFixed on an array.
This is the object assigned to const "l" (that's a lower case "L") in the _ function in wfsUtils.js
"type": "LineString",
"coordinates": [
-72.65184826276831,
41.68332079297852
-72.6518375426355,
41.6833402003078
-72.65164952810201,
41.68368523520941
-72.65134688182289,
41.68423819295341
-72.65133217881116,
41.68426533549341
-72.6511336731859,
41.68463172535813
-72.65111840159392,
41.68465905375734
This gets interpreted as a 'lineString', type, and a switch/case assigns l.coordinates[0] to e
It seems like this is the issue. With these coordinates, the assignment should go a level deeper: l.coordinates[0][0] (which is what the switch/case uses for types MultiLineString and Polygon.
The question here is this -- is my service returning the wrong type and/or coordinates data, or is wfsUtils handling this wrong?
Any help or clues would be appreciated. Thanks!
(Using ArcGIS JS API 4.22 via npm package in an Angular 12.1 application)
